70 Rear Valence Bracket Finish - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    R the brackets to reinforce the rear valance on a 70 finished in semi-gloss black or zinc phosphate?
    Bill
  • Ron G.
    • December 1, 1984
    • 865
    Re: 70 Rear Valence Bracket Finish
    Bill,
    Could you be a little more specific or even provide a photo of the bracket in question. Thanks.
    "SOLID LIFTERS MATTER"
    • Bill L.
      • February 1, 2004
      • 1403
      Originally posted by Ron Goduti (8076)
      Bill,
      Hi Ron,
      Note that the bracket has been dipped to remove dirt and rust so it is pictured as bare steel.
      • Ron G.
        • December 1, 1984
        • 865
        Bill,
        That particular bracket and most of the ones similar to it in configuration were dipped painted in GM # 1050104. Pretty much the same paint that was used to black out the wheek wells ansd the engine compartment unless it was a car being painted black at the factory as then they would blacked out the engine compartment with the lacquer paint used to paint the exterior. What this did was eliminate setting up the other bkack paint. This pretty much holds true for most factory black painted vehicles.
        • Bill L.
          • February 1, 2004
          • 1403
          Thanks Ron,
          The reason I thought maybe this bracket was different is because of the captured nut.
          Bill
          • Ron G.
            • December 1, 1984
            • 865
            Bill,
            Just an FYI - If you are dipping parts or spraying them with the # 104 paint, it is not necessary to incorporate thinner as it is made to spray right out of the can after a good stirring.
