Upper hinge access panel: screws and sealant - NCRS Discussion Boards
+ More Options
Posts
  • Doug J.
    • April 1, 2005
    • 140
    On the upper hinge access panel, is the washer separate from the screw head, or part of the head; would it be A or B in the photo? What type of sealant, or gasket, if any, was used to seal the cover to the door jamb? Lastely, what would be the size of the screw head...I'm thinking 5/16 ?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Upper hinge access panel: screws and sealant
    A, thin foam w/s, 5/16
    • Ron G.
      • December 1, 1984
      • 865
      Doug,
      Is it possible for you to provide a quality photo ?
      "SOLID LIFTERS MATTER"
      • Doug J.
        • April 1, 2005
        • 140
        Wayne...Thank you, I figured thats how it went, just wanted to make sure.
        Quality photo ?? That's as good as it's going to get Ron, sorry. It's obvious that screw "A" has a washer head nut, and that screw "B" the washer is seperate from the nut head.
        • Ronald D.
          • March 11, 2012
          • 66
          I just took my doors off yesterday, it is screw #A, my doors have never been removed before, orig screws.
          • Doug J.
            • April 1, 2005
            • 140
            Thank you Ron, that confirms Wayne's answer also...not that I ever thought he was wrong.
