I have tried numerous times to remove the center AC dash vent on my '66 coupe without success. I need some advice on removing the vent bezel and deflector without destroying something. I have loosened the bezel from the center dash and the deflector rotates freely within the bezel and it seems as though I can pull the bezel/deflector out but the unit seems to be hanging up on something when I move it out about an 1/8 of an inch. I have consulted the AIM and it appears to me that the deflector is installed first into the bezel and then it just rests inside the semi-cylindrical cutout part of the center air duct.
Also, once I remove the deflector, the semi-cylindrical part of the air duct, which is metal on my car, needs cleaning and some slight surface rust removed. I assume that this metal part was never painted. Is that correct? I will greatly appreciate any help.
Jim
Jim
