C2 Coupe Door Latch Removal & Reinstall - NCRS Discussion Boards
  • David J.
    Infrequent User
    • September 30, 1990
    • 28
    Anyone have some insight into removing the door latch in a '67 coupe. Is removal of the rear metal run required to remove the door latch? If so, is it necessary to remove the glass before the rear metal run can be removed? It seems the coupe channel liner is riveted to the rear metal run and extends from the lower rear door to the top of the window.
    Thank you
