1965 365hp - Glove Box Door - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    Hello All; I recently bought my 65', and wish to repair/replace my glove box door which is slightly dented and scratched. Should I send this original unit for repair, or simply change it ? I'm concerned that the replacement unit will not be of same quality and finish as OEM. Thank you; David Kalaydjian
  • John M.
    • January 1, 1998
    • 813
    Re: 1965 365hp - Glove Box Door
    David, If it's just the brushed aluminum facing you can repair this yourself.
    Check the archives, I think the method is described there. If not, let me know and I'll get you some instructions.
    John
    • Paul J.
      • September 9, 2008
      • 2091
      I believe that the entire procedure was in an article by Jerry Fuccillo in a 2007 issue of the Restorer, which is available at the NCRS store. I also recall that parts of this article are in the archives somewhere.
      Paul
      • Doug L.
        • March 14, 2010
        • 442
        Just did my '64. You can buy the brushed insert, cut the old one out leaving ~ 1" all the way around, paint the surround then slide the new insert between the old insert and the back side of the surround. If you drill the rivets out of the back side you ruin the originality. Sliding the new insert in preserves the door as original.
