C1 Power Top - NCRS Discussion Boards
C1 Power Top
  • Tony P.
    • December 11, 2008
    • 84
    C1 Power Top
    Are the componets for a 61-62 the same for a 57
  • Mike M.
    • May 31, 1974
    • 8382
    Re: C1 Power Top
    can't coment on 57 vs 61-2 but can on the 56 vs 57. harnesses differ as do conv top lid saftey switches and the location of the other switches. i'm currently doing a early 56 which has been a headache. i've got 57 parts if ya need any.mike
    • Tony P.
      • December 11, 2008
      • 84
      Re: C1 Power Top
      Thanks,I found a guy who had a complete set up but he told me its from a 61-or 62.I cant remember whitch one but I said that I would try and find out if either year would work for me. Im going to try and find the complete set up if I can,the only thing I have is the switch and the relay that sits under the hood.
      Thanks Tony
      • Joe M.
        • April 30, 1990
        • 1338
        Re: C1 Power Top
        Tony, the main difference between 57 and 58-62 is the push/pull switch under the dash for the 57. In 1958, they changed over to a toggle switch under the dash. The microswitches, relay, safety switches, solenoids, pump/motor, wiring harness is the same for 57-62. You can expect to spend around $1,700 to get a complete set up working; unless you are purchasing the complete set up from one of the 2 men that refurbish them and they are ready to plug and play when you take them out of the box (plus tweaking of the micro switches).
        • Tony P.
          • December 11, 2008
          • 84
          Re: C1 Power Top
          Yes his set has a togle switch.Can you give me the info on where I can get one ready to go?
          Thanks Tony
          • Joe M.
            • April 30, 1990
            • 1338
            Re: C1 Power Top
            Contact John Shell, 260-749-8201. He will sell you a complete set up if he has one for sale or he can take a non-functioning set up that you provide and make it ready to install. The push-pull underdash switches for pre-1958 power tops are available on ebay or Doc Rebuild. You can sell the toggle switch for around $100 on ebay.
            • Tony P.
              • December 11, 2008
              • 84
              Re: C1 Power Top
              Thank you very much!
              • Gary C.
                Administrator
                • October 1, 1982
                • 17657
                Re: C1 Power Top
                Tony, Dave Ewan at one time had a complete set up for 1957. Call Dave 817-482-1978 Gary....
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Joe M.
                  • April 30, 1990
                  • 1338
                  Re: C1 Power Top
                  Yes he did and it was a fair price.
                  • Tony P.
                    • December 11, 2008
                    • 84
                    Re: C1 Power Top
                    Thanks!!!!
