C5 Ice removal - NCRS Discussion Boards
C5 Ice removal
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12794
    C5 Ice removal
    What is the recommended procedure from removal ice from C5:
    Rob.
    NCRS Software Developer
  • Mike E.
    • June 24, 2012
    • 920
    Re: C5 Ice removal
    Not to be a smart ass but how about a warm garage? I took my '01 Z out of the garage once on ice. I couldn't get it out of the driveway. With big tires I don't see how anyone can drive a C5 or C6 in cold snowy weather. Rob, I applaud you for trying, you're a braver man than I.
    Mike
    • Brian M.
      • February 1, 1997
      • 1840
      Re: C5 Ice removal
      Move to a warmer climate.
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12794
        Re: C5 Ice removal
        Mike
        I have (very expensive) snow tires... It my daily driver (but not today )
        BTW I need all the garage space I have for the vintage Corvette's...
        Rob.
        • Jack C.
          • September 30, 1992
          • 1090
          Re: C5 Ice removal
          My nephew thought he would be a big help and try to remove the ice off of my brother-in-law's car, with a hammer. Watch out.
          Jack Corso
          1972 Elkhart Green LT-1 Coupe 43,200 miles
          Top Flight 1994, 2018 & 2021
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12794
            Re: C5 Ice removal
            I might try these airplane de-icing guns
            Rob.
              • 15610
              Re: C5 Ice removal
              Those airplane deicers use heated Ethelyn Glycol. I am sure that is not cheap -- oh and I doubt there will be any foliage growing around the driveway in the spring. Good luck.
              • Rob M.
                NCRS IT Developer
                • January 1, 2004
                • 12794
                Re: C5 Ice removal
                Ok, so it saves me time on de-weeding as well!!!
                Rob.
                • Larry M.
                  • January 1, 1992
                  • 2700
                  Re: C5 Ice removal
                  Or any cats, dogs, or other wildlife in the neighborhood............... Intake/drinking of the EG solution will likely result in organ (kidney) failure.
                  Larry
                  PS: In the chemical plants where I worked, we made EG for antifreeze and polyester fiber. Some of the older supervisors used to taste/sample the EG to modify their operating conditions rather than wait for the lab results.
                  They're all gone now.
                    • 15610
                    Re: C5 Ice removal
                    I don't thing Ethylene Glycol is a selective herbicide, but Paul O will know more about that than I would.
                    • Keith B.
                      • March 7, 2008
                      • 928
                      Re: C5 Ice removal
                      park it in the sun.
                      • Michael W.
                        • April 1, 1997
                        • 4290
                        Re: C5 Ice removal
                        Rob-
                        As a Canadian, I assure you that there is a sure-fire cure for your plight. It's called 'spring'. In the old days, this started in early July for us but with the clever invention of global warming, we now bask in it's warmth as early as late June.
                        • Jim T.
                          • March 1, 1993
                          • 5351
                          Re: C5 Ice removal
                          Not knowing your driving intentions, when I experience freezing rain that makes my Monte's doors frozen shut and ice on the windshield I pour cold tap water from the house around the door and on the windshield. The door will open and the water on the windshield makes scraping easier. Corvettes are in the garage.
                          • Russ S.
                            • April 30, 1982
                            • 2162
                            Re: C5 Ice removal
                            Garden hose-preferably hooked up to warm water.
                            • Steven B.
                              • June 30, 1982
                              • 3997
                              Re: C5 Ice removal
                              Rob, I grew up in the north and had this problem all too frequently, lived in apartments, I used the water method and in later years I used a hair drier to melt the ice. After you melt it wipe down the weather stripping and jambs to assure they are dry. (The water usually worked faster than the hair drier. If you use the hair drier don't get it too close to the body.) After that step I would apply glycerin to the weather stripping and then coat them with baby powder to prevent the stripping freezing to the body next time.
                              Steve
