master cylinder #5459467 - NCRS Discussion Boards
  • John S.
    • July 29, 2009
    • 640
    have a #5459467 that i had marked for a 74 corvette. is this the correct number? if not, what is this master cylinder used on?
    • 43202
    Re: master cylinder #5459467
    John-----
    I am not familiar with that casting number as ever having been used on a Corvette. Does the master cylinder have a 2 alpha character broadcast code stamped into it and, if so, what is it?
    • Russ S.
      • April 30, 1982
      • 2161
      correct for 73-73 are #5460346 for PB and 5455509 for manual brakes.
      • John S.
        • July 29, 2009
        • 640
        John-----
        code is either a AP or AF.
          • 43202
          John-----
          I can't find any Chevrolet application for that code but it's very possible there is one. It's also possible that it's a non-Chevrolet GM application. The master cylinders were usually Delco-Moraine part numbers and could have been used on any GM product.
          • Paul O.
            • August 31, 1990
            • 1716
            My search resulted in that casting number was for a 1967 Camaro manual brakes.
              To clarify, that usage was 1967 manual (non-power) DISC front brakes; not many of those were built.
              • John S.
                • July 29, 2009
                • 640
                thanks, had the master cylinder rebuilt about 35 yeays ago when i had camaros and i lost track of having any camaro parts.
