Radiator hose - NCRS Discussion Boards
Radiator hose
  • Phil A.
    • April 30, 1982
    • 121
    Radiator hose
    Does anyone know where to get the ncrs correct upper and lower radiator hoses for a 1971 LT1? Thanks in advance. Phil
    • 15616
    Re: Radiator hose
    Not exactly where, but this should help you determine what is "NCRS correct" (if there is such a thing). Based on this thread you ought to be able to sort out the correct upper hose for your 1971. Knowing that is a good part of the battle.
    https://www.forums.ncrs.org/showthre...-radiator-hose
    • Dave S.
      • August 31, 1992
      • 2926
      Re: Radiator hose
      Phil,
      My 71 LT-1 had the original 3946852 with AU and a white stripe on it. I believe the TIM & JG says it should have JP AU on it.
