Re: Fuel Injection gear pump relief hole orientation
I have used one distributor. Two different pumps and have spun it using drill to see if I can replicate without pumping fuel. The one area I'm thinking through right now is the modification done to prevent lean condition at high flows. It's a restrictor in the spill valve nozzle area that reduces the effective area that the "thumbtack" acts on. This helps with control but also would restrict spill back into fuel reservoir if the annular area created for the given travel of the "thumbtack" is inadequate. But if this were true I would think I would go rich at high RPM and its pretty stable. Have to think about this some more. Believe me, I wouldn't be going through all this pain if I wasn't determined to be at Monterey with my original injection on it.
