Heat/Noise Floorpan Wrap - Pros and Cons - NCRS Discussion Boards
  • Clark E.
    • March 1, 1991
    • 163
    I'm considering installing a thermo blanket (Eastwood) against the floorpan before the new carpeting and would appreciate comments as whether the product is worth the expense and if it impacts judging. I still have the jute material from the original carpeting. Thanks...Clark
  • Gary C.
    Administrator
    • October 1, 1982
    • 17771
    Re: Heat/Noise Floorpan Wrap - Pros and Cons
    Clark,
    Several good articles in past Restorers magazines about floor insulation. The one I wrote in 2008 had heat test results in it. Best heat reduction material I found was http://www.hushmat.com/
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Paul J.
      • September 9, 2008
      • 2091
      You will lose points if the judges see it or detect it. You will also never get it off once you put it in.
      Paul
      • Clark E.
        • March 1, 1991
        • 163
        Thanks Gary...I plead ignorance. How do you access Restorer articles?...Clark
          Clark -
          If you don't have the original issues, the NCRS Store sells DVD's that cover every issue ever printed. See page 130 in the current "Driveline".
