L71 balancer pulley - NCRS Discussion Boards
L71 balancer pulley
  • William O.
    • January 23, 2008
    • 1
    L71 balancer pulley
    Any one know the correct balancer pulley for a 67 L71.....I know its 3863108......but is it BF...or BM...or is it the one with the cast numbers on the front edge and not next to the windows.....I guess what i am asking is which one passes judging
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11327
    Re: L71 balancer pulley
    I searched "3863108" and came up with a few interesting threads. Not conclusive but there are a few photos of each type in the posts. The L71 I worked on a few years ago used the reproduction, with the part# cast on the outer edge. Not sure how it would judge. The JM does not specify features.
    Rich
    https://www.forums.ncrs.org/showthre...hlight=3863108
    All search results here....3863108
    • Wayne M.
      • March 1, 1980
      • 6414
      I thought that top pic looked familiar . [is on my late 396]
        • 43246
        William-----
        If I recall correctly (and I may not), the "BF" broadcast code was used for the GM #3921923 stamped steel pulley used for many 1968-74 Corvette big blocks
        Correction: I had it backwards, The "BF" broadcast code was used for the cast iron GM #3863108 pulley and the "BM" broadcast code was used for the stamped steel GM #3921923 pulley. How the cast iron pulley pictured in this thread got the "BM" code, I have no idea. The 2 pulleys are functionally interchangeable but there would have needed to be different broadcast codes so that assembly line workers knew which pulley to install for a particular application.
        • Hebert K.
          • September 5, 2011
          • 33
          William,
          The one that is on my 67 L71 is 3863108 BF.
