Spare tire tub - NCRS Discussion Boards
Spare tire tub
  • Morris R.
    • May 7, 2012
    • 213
    Spare tire tub
    Someone painted the spare tire tub black on a 66 corvette,is there a product out that will strip the paint off without damaging the fiberglass? Thank you
  • Howard W.
    • December 1, 1998
    • 121
    Re: Spare tire tub
    Lacquer thinner and a scrub pad
      • 6950
      Re: Spare tire tub
      Or paint remover.
      • Michael H.
        • December 1, 1987
        • 731
        Re: Spare tire tub
        Try this stuff as I used it on my tire tube with no issue's is called "Kleen Strip" aircraft stripper for fiberglass , marine grade .Its a gel you brush on , works great , takes the paint off to the factory primer . not super strong like regular aircraft stripper. Make sure you get the kind that works OK with fiberglass as they make two different kinds of stripper. You can buy this at a good parts store or hardware store.
        Mike
