Tight Casting Date - NCRS Discussion Boards
Tight Casting Date
  • Walter R.
    • January 6, 2009
    • 275
    Tight Casting Date
    I am considering a purchase of correct 942 block for 66. The casting date is 5 days before the assembly date. Will this pass being so close? I know a date further out would be the norm but the block is standard bore and in very good shape.
    Re: Tight Casting Date
    Walter -
    Which assembly date - for the engine, or for the car?
    • Walter R.
      • January 6, 2009
      • 275
      Car Assembly
        Car Assembly
        Walter -
        What's the block casting date AND the engine assembly date stamped on the front pad, and the car assembly date?
        • Walter R.
          • January 6, 2009
          • 275
          Block Casting Date- 2/9
          Engine Assembly- Decked no #
          Car Assembly- 2/14
            Car Assembly- 2/14
            Walter -
            That casting to car assembly time span isn't impossible, but it's pretty tight for a big-block; most big-block castings sat longer than that before being machined/assembled.
            • William C.
              • May 31, 1975
              • 6037
              Plus transit time from tonawanda to St Louis.
              Bill Clupper #618
