94 Zr-1 wipers - NCRS Discussion Boards
94 Zr-1 wipers
  • Andrew S.
    • January 30, 2013
    • 9
    94 Zr-1 wipers
    I am trying to figure out what the correct windshield wipers look like for a 94 Zr-1. They appear to be smaller that the 95.
    Anyone know what the original ones should look like?
    Andrew
  • Ed N.
    • May 16, 2010
    • 1003
    Re: 94 Zr-1 wipers
    Andrew, shouldn't they be the same as the 94 and 95 Corvette? If they are, these are still available through GM.
    Ed Nieves
    NCRS #51799
    • Andrew S.
      • January 30, 2013
      • 9
      Re: 94 Zr-1 wipers
      They are different, I trying to put the 95 (correct ones) on the 94 and the arm is too small. Don't understand it. Are they the same wipers that came on the base 94 or are they different?
      • Ed N.
        • May 16, 2010
        • 1003
        Re: 94 Zr-1 wipers
        Andrew, acording to the JM, the 95 ZR1 has the same blades as the 95 non ZR1.
        Ed Nieves
        NCRS #51799
        • Ed N.
          • May 16, 2010
          • 1003
          Re: 94 Zr-1 wipers
          Andrew, you shouldn't have to change your arms, just the blades.
          Ed Nieves
          NCRS #51799
          • Andrew S.
            • January 30, 2013
            • 9
            Re: 94 Zr-1 wipers
            You are correct. When I went to put the new blades that I ordered in the mail, the spot where you place the new blades was where the issue was. maybe I ordered the wrong ones. They fit the 95 but not on the 94. I could be overlooking something
              • 43247
              Re: 94 Zr-1 wipers
              Andrew
              Andrew-----
              The base Corvette and ZR1 wipers were the same. Also, they are NOT the same as 1995 and later.
              Except if your car was originally equipped with C18 (check your service replacement parts label for this code), the original wiper blade assemblies were 20" Trico. These are no longer available and have not been available in over 16 years. Since then, the current GM replacement blades are GM #12363800. These are 20" Anco.
              • Andrew S.
                • January 30, 2013
                • 9
                Re: 94 Zr-1 wipers
                Thank you for the information and the quick responses. Loving this forum already. Will check this in the soon. Work and School are getting in the way tonight.
                • Ed N.
                  • May 16, 2010
                  • 1003
                  Re: 94 Zr-1 wipers
                  Andrew, joe is the man. I would listen to him. Nevertheless, the blades should snap right in.
                  Ed Nieves
                  NCRS #51799
