When I bought my car it had a dent in the vacuum advance canister so the distributor could be turned more counter clockwise toward the fuel injection plenum to set the timing correctly. Didn't look right to me. So during restoration I put on a new vacuum advance. But in order to get the timing for good idle I had to set the distributor one tooth off clockwise to prevent the canister from hitting the plenum. As a result I cannot read the timing using the tab on the timing chain cover.
Recently I was searching past posts on this Discussion Board and came upon discussion of this problem. But the solution was not clear to me. Can someone clarify how to deal with this correctly?
I have verified that the distributor gear is installed correctly and the igniton wires are in the proper location on the distributor cap. The engine was rebuilt and the cam changed before I bought it. Cam is unknown.
I read one post in which it stated that the poster had spoken with a worker at the engine assembly plant that said they used to whack the distributor advance control with a rubber mallet and dent it against the plenum...just like I found mine! Is this the correct procedure?
