Adding Vintage Air - NCRS Discussion Boards
Adding Vintage Air
  • Richard G.
    • December 20, 2012
    • 15
    Adding Vintage Air
    If I add Vintage air to a 1967 427, would that hurt the value?
    Can it be removed it when I sell it without hurting the value?
    Richard Green (57800)
    Fredericksburg, Va. 22405
  • Dick W.
    • 10483
    Re: Adding Vintage Air
    If you are careful when you make the installation, save all the pieces you remove, it should not add or detract from the value. It can be removed and you will never know it has been there. Installed a couple of kits, not the easiest thing in the world for a fat old man to do, but a well engineered kit
    Dick Whittington
    • Bruce B.
      • May 31, 1996
      • 2930
      I put Vinatge Air units in a few 62 Corvettes and I used thier small street rod unit not thier "direct fit" model.
      Very easy install, but you need to borrow (or buy) a hose crimping tool for proper installation.
      Also be sure to specify compressor mount on the passenger side and alternator on drivers side.
      • William F.
        • June 9, 2009
        • 1364
        At least on the hi perf '62's GENERATOR( not alternator) is on the passenger side.
        • John S.
          • May 4, 2008
          • 424
          Richard,
          I installed it on my 67 small block car. Top flight car before and after install. Sure needed it in a black car! I bagged and tagged every single piece I took off and saved in the Vintage air box. Could not bring myself to drill a 5/8 hole in the firewall so I have the condensate hose in the cab draining to a plastic water bottle. Works great! I know car can be put back to original in a weekend if next owner wants it that way. Next car I get may have to have original a/c, that is unless it is a high horse car. Then I guess I would have to suffer!
          john
          John Seeley
          67 Black/Teal
          300 hp 3 speed coupe
          65 Maroon/Black
          35k mile Fuelie coupe
