Can't Find #90 Bulb for Parking Brake Alarm-1960 - NCRS Discussion Boards
  • Dick W.
    • 10483
    Re: Can't Find #90 Bulb for Parking Brake Alarm-1960
    Good catch Dick.....I was wondering where that #90 reference came from. It'll never fit in the single contact socket for those applications. It's too big.
    It's amazing how all these "little things" can be so much of a PITA.
    I see on the Sylvania website it calls out the #90 for the Brake Warning lamp in error. S/B #53.
    Here is the spec for the #53 bulb.....
    For over 100 years, SYLVANIA has delivered lighting expertise with reliable headlights and enhanced visibility—putting light where you need it. Shop LED bulbs, fog lights, and off-road lighting from the #1 aftermarket automotive lighting brand in the USA.
    And the #57 spec here....(for other dash bulbs)
    Joe, Try the #53 that may be in the HB indicator socket in your EB flasher to see if it works better.
    The catch comes from starting to work in a parts room in 1956, plus fleet, and then the Corvette parts business. Just arbitrarily look things up without thinking. 57 years of looking at books is a hard habit to break.
    Dick Whittington
    • Donald H.
      • November 2, 2009
      • 2586
      Lectric Limited lists the #53 bulb in their kit as being for the Emergency Brake Light. The ST-12 is really messed up. Spec page 14-18 shows 1959-58 Park Brake Alarm bulb as #90, but then listes 1962-60 as being #257 which I think is the flashing bulb.
      Don Harris
      • Joe M.
        • April 30, 1990
        • 1338
        OK, I am finally over the #90 bulb. I noticed that it was a double contact 15 millimeter wide bulb and the dash bulbs are single contact
        9 mm wide bulb. I kept thinking that I would find a single contact 9 mm #90. The #53 bulb makes sense since it is the size of the dash light bulbs. All of the parts stores carry the #53. Thanks to all for getting me to the truth finally.
        • Charles P.
          Infrequent User
          • April 1, 1989
          • 1
          I just checked Corvette Central and did a search for "brake warning flasher bulb" and got 3 different bulbs for use in the brake flasher.
          • Joe M.
            • April 30, 1990
            • 1338
            The #53 I installed yesterday is working perfectly today.
