Heater controls on a 1963 corvette - NCRS Discussion Boards
  • Raymond R.
    • June 30, 1988
    • 115
    There are two knobs that you pull out to operate the heat in a 63 vette. One is for Fan - Temp. The other is for Air - Defrost. As I was using the heater, I pulled them out. Now they only go back half way. Any ideas as to the problem and how I fix it? Thanks.
  • Harry S.
    • July 31, 2002
    • 5293
    Re: Heater controls on a 1963 corvette
    Sounds like they came loose at the heater box or they are filled with dirt and stuck. Remove the glove box and see if they came loose.
    You may need to remove them from the car for a good cleaning and lube.
    • Raymond R.
      • June 30, 1988
      • 115
      Thanks. I will give it a try.
