Big Block engine heat - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    The big blocks are notorious for running at higher temps. What factors in an engine rebuild will affect the operating temp? Will dropping the compression ratio help the engine run cooler? How about porting the heads? Cam selection?
    • 15661
    Re: Big Block engine heat
    It has nothing to do with anything you mentioned and everything to do with the spark advance map. Google my name along with Corvette and San Diego and go over my national convention presentation.
    • Larry B.
      • October 21, 2012
      • 71
      If you want to cool the engine it has to do with circulation of water.If you don't think so take and get the car good and hot then take aheat gun and check the temp at the front of the head and the back of the head .A differance of 40 to 50 degrees is common.There is nothing to make the water go to the back the only outlet is in the front going back to the radiator'The heads have holes in them all you have to do is drill the manifold and let water out the back to the radiator and the temps will drop.
