Looking for some input on compression ratio selection for rebuilding an L72 to run reliably on pump gas. I have experience with two prior 396's that were built to 10.5:1, and with optimal tuning I was able to run them on pump hi-test, but that experience tells me any more compression than that will be a problem. I found this magazine article awhile back that I kept bookmarked... http://www.corvettefever.com/techart..._engine_build/ I thought it was an interesting build, the end results appear to prove out the changes they made to the engine, and the only real additional expense would be the additional relief machining on the pistons. Thoughts?
Steve
Steve
