1968 shroud bracket #3935570--available original or reproduction? - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    1968, big block, rad. shroud to support bracket, 3935570.
    Are these available?
    George
    • 43246
    Re: 1968 shroud bracket #3935570--available original or reproduction?
    George
    George-----
    GM #3935570 was discontinued without supercession in July, 1977. This bracket is a unique-to-1968-Corvette big block sort of piece. I don't know of any source for it.
    • George W.
      • May 31, 2000
      • 544
      I was afraid of that.
      Thanks Joe,
      G
      • Henry J.
        • November 1, 1999
        • 457
        George:
        I recall looking for this part in the reproduction marketplace some time ago but couldn't find it.
        • Dale C.
          • November 1, 1999
          • 844
          George
          Look at Corvette Central P/N 243026. I said it's a 68 upper but it looks alittle different.
          RADIATOR UPPER SUPPORT BRACKET
          Item# 243026, 1968
          $31.00
          Add to Cart+-View
          Dale
          • Henry J.
            • November 1, 1999
            • 457
            Dale:
            I think that part is for a small block application.
            As you suggested, it looks different than the one on my big block, which I believe to be original.
              • 43246
              Originally posted by Henry Jakubiec (33095)
              Dale:
              Henry and Dale------
              Yes, I believe the the CC part is the small block piece. The big block and small block brackets are similar but they are not the same. Would the small block piece be usable, as-is or modified? I don't know.
              • Dale C.
                • November 1, 1999
                • 844
                Here is a picture of Mine
                Dale
                • Scott K.
                  • February 1, 1980
                  • 59
                  George
                  Corvette Central is going to produce this part. It is currently in development.
                  Corvette Central
                  800-345-4122
                  www.corvettecentral.com
                    • 43246
                    Scott-----
                    Thanks very much. It's always nice to hear that someone is "stepping up to the plate" to make Corvette restoration parts available.
                    • George W.
                      • May 31, 2000
                      • 544
                      Any update?
                      • Scott K.
                        • February 1, 1980
                        • 59
                        It is still in development, but we currently have an original one for sale on our new CC Swap Meet site. You can view it here or visit http://www.corvettecentral.com/swap-meet/
                        Corvette Central
                        800-345-4122
                        • Dale C.
                          • November 1, 1999
                          • 844
                          Scott, I may be mistaken but looking at the two different support assemblies in the AIM, for small block 11-13 B5 (3919752) and the big block and A/C cars C60 B3 and L36 A 11, (3935570), I think the difference may be in where the retention nuts are welded to the bracket. The small block looks as though the two welded nuts hold the two bolts # 7 on the back side. Whereas the big block has only one bolt and nut on that side and has two screws #1 going into two welded nuts on the top of the 3935570 bracket. This could be important if you are reproducing the BB part as that one you have listed may in fact be the 3919751 depicted on 11-13,B5 by the position of the welded nuts. Could also be selling the wrong part to someone. I think my BB has the two nuts welded to the top and I wonder if other A/C BB's are that way also? They, like Joe said, may be quite similar and interchangeable, as they can fit both the C60's, small block and big block. Dale
                          • Grant W.
                            • December 1, 1987
                            • 407
                            hi Scott
                            Just looked at your 3935570 and that is NOT a 68 BB shroud bracket. Actually fits 69
                            If you take the 2 welded nuts off. Fill in the holes. Use the welded nut and tack it to the middle and there you will have a Big Block only 68 fan shroud bracket
                            Hope this helps
                            Grant
                            • Steve W.
                              • March 1, 2002
                              • 78
                              Dale's picture looks exactly what is on my 68 L71 (427 / 435).
