57 Tach - NCRS Discussion Boards
57 Tach
+ More Options
Posts
  • Tony P.
    • December 11, 2008
    • 84
    57 Tach
    I changed my 57 to an alternator and now Im using a tach driven distributor. Now my tach is not reading properly. Im wondering if anyone can re calerbrate the tach to go with the distributor. I want to keep the dash stock appearing so a tach on the column is not an option.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 57 Tach
    Tony,
    A tach drive distributor turns at 1/2 the speed of a tach drive generator therefore you will have low readings on the tach, actually 1/2 the actual RPMs.
      Re: 57 Tach
      Any of the usual instrument specialists can rebuild/recalibrate the tach head to read twice cable speed (from the distributor) instead of full cable speed (from the generator gearbox); the tach came both ways originally, depending on the engine application. I'm sure Brian Tilles (Corvette Specialties of Maryland-West) can do it.
