right turn signal ? - NCRS Discussion Boards
right turn signal ?
  • Wayne P.
    • January 23, 2008
    • 444
    right turn signal ?
    replaced the bulb and still not working. What would be the best procedure to check why this turn signal light isn't working. The turn signals do work on the car just the dash right light not working. Might be turn signal part in column ? Replaced all the other light bulbs works grate.
    You can tell by my posts that it is winter here. Getting ready for spring can't wait.
    • 6958
    Re: right turn signal ?
    Wayne, check the switch and make sure the wires are plugged in and no wires broken. I believe the dk. blue wire heads to dash from turn signal switch.
