63 antenna - NCRS Discussion Boards
63 antenna
  • F H.
    • March 1, 1982
    • 26
    63 antenna
    I would like to drop or lower the antenna to mark a car cover opening on my 63 roadster. Antenna I believe is original. Bezel has 2 small openings at 180 degrees. Thoughts on unsrewing without damage. Thanks.
  • Wayne P.
    • January 23, 2008
    • 444
    Re: 63 antenna
    I believe I made my own tool bending a piece of metal rod. I placed painters tape over the antenna Benzel.
    Hope this helps .
      • 6941
      Re: 63 antenna
      Along with the top nut there is a bracket that attachs underneath the car, don't forget this as if you start pushing the rod the bracket may break or bend something. Also the muffler may give you a hard time because its in the way. try dropping the rear muffler hanger and see if this helps.
      • Philip C.
        • December 1, 1984
        • 1117
        Re: 63 antenna
        I gues your marking it to cut a hole for the antenna. Put the cover upside down on the car and mark it on the passenger side. Phil 8063
        • John D.
          • December 1, 1979
          • 5507
          Re: 63 antenna
          LI has a perfect spanner wrench for the chrome bezel.
          By the way a 63 antenna can be changed without removing or doing anything at all with the muffler. Now it's not easy and requires a helper but it can be done. JD
