Antifreeze leak at cylinder head. Do old heads become porous? - NCRS Discussion Boards
  • Raymond R.
    • June 30, 1988
    • 115
    I thought the leak was from the first bolt in the cylinder head. I took the bolt out. Cleaned it. Put on permatex and reinstalled. It now looks like the leak is from the casting below the bolt. The engine is a 327 ci, 250 hp. It doesn't look like there is a crack. It looks like the antifreeze is coming out of a pin hole. These are original heads. Do they become porous? If so, can they be fixed?
    • 43221
    Re: Antifreeze leak at cylinder head. Do old heads become porous?
    Raymond------
    They do not suffer casting porosity, per se, as a function of age and use. However, they can become cracked (even though the crack may be difficult or impossible to see with the naked eye) or they can suffer corrosion damage over time which can result in a leak. I've never seen a block or head casting rust-through, though.
    You might try adding a HD sealer to your coolant to see if that solves the problem. You should be doing this anyway. Use GM #3634621.
    • Raymond R.
      • June 30, 1988
      • 115
      Thanks Joe. I will give the HD sealer a try before I start tearing it down.
