1968 Reproduction Center Console Help - NCRS Discussion Boards
+ More Options
Posts
  • Bob S.
    • May 31, 1986
    • 254
    Placing a new Center console in place, I see that the sides that rest on the "Tunnel" don't lay on the carpet like the original. It sticks up enough to put a finger under it. I haven't installed the screws on either end yet. Don't know if this will help.
    Anyone run into this? Also, is a Heat Gun an idea?
    Bob DeSimone
    (9944)
    CODE][/CODE]
  • Dale C.
    • November 1, 1999
    • 844
    Re: 1968 Reproduction Center Console Help
    I had good luck with my #8929-20 fron Paragon. It is the padded type and not the hard plastic kind.
    • Bob S.
      • May 31, 1986
      • 254
      I wish I had checked with Paragon first...I've got this one now. I guess I'll buy a heat gun and just work it into place. I was watching Mecum last night and noticed a C-3, and the console seemed a bit "Off" the carpet as well. However, I want it to be "RIGHT"
      Thanks for your help!
      Bob DeSimone
      (9944)
