Harmonic Balancer Leak help - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    When I had my engine rebuilt 3 years ago I noticed a small oil leak coming from the harmonic balancer at the bottom lip.
    I replaced the seal and re installed. It began to leak again . I then placed a seal a metal seal over the harmonic balancer shaft that had no scoring on it. It still has a small leak while the car sits .
    I also placed seal compound in the key way slot .
    Does the seal need time to work in or is their another common issue I am over looking .
    Regards
    • 6956
    Re: Harmonic Balancer Leak help
    Wayne,I am not a big lover of the metal sleves unless theres a grove that you can feel with your finger nail. What I have done in the pass is take some 400 sand paper and smooth out the surface on balancer and replaced the seal( smear some non handing sealer around the metal seal before installing).
    What I have seen with those repair sleves,When installing them if not careful they will distort and will leak.
    • Wayne P.
      • January 23, 2008
      • 444
      Thanks the metal sleeve whent on fine with locktite red. Very smooth surface. maybe pull balencer out a bit and coat with non hardening seal ? Seal is new,
      • Timothy B.
        • April 30, 1983
        • 5201
        It has been reported to put sealer around the keyway when installing as this is a leak path for oil.
          • 6956
          Wayne, you coat only the metal outer part of seal when installing. not the rubber lip.It could be when installing the seal also there is a spring that holds the lip of the seal in place around the harmonic balancer, this spring if it came off during the install the seal will also leak.I would say just to replaced the seal again. Its a a pain to work from above and sometimes makes for installing the seal a bit work.
          • Wayne P.
            • January 23, 2008
            • 444
            Ok I didn't put any sealent around the metal part of the seal when I inserted it into the cover. I will also check for the metal spring. I guess I will get another work out . I am glad I have the proper installer tools. Cheers
            • Ray G.
              • May 31, 1986
              • 1189
              Wayne;
              The surfaces on which you are using sealer need to be almost sterile. Any lubricant or foreign material in the contact area will create a path for the oil to follow.
              Silicone sealer on the outer metal surface of the seal and on the inside of the Harmonic dampener. I also take the key out of the keyway and put silicone in the crankshaft slot.
              Also a Light coat of lubricant on the seal lip.
              my .02
              I hope you dance
              • Dick W.
                • 10483
                Have used many Speedi Sleeves since their inception. The keys are to use the proper tools, follow the instructions, and use #2 Permatex on the outside of the seal, the inside of the sleeve paying extra attention to the keyway. Lubricate the sealing surface with a light coating of grease and you should be good to go.
                Dick Whittington
                  • 43273
                  Wayne-----
                  Usually, the outer perimeter of the steel shell of the seal is pre-coated with a sealer. Most of the time it will be seen as a reddish or greenish color.
