Rear Body Filler Panel Attaching Reinforcement Plates -1970 - NCRS Discussion Boards
  • Clark E.
    • March 1, 1991
    • 163
    The bottom edge of body panel below the rear light assemblies on each side has two indentations with three holes for small steel plates. Each plate is held to the body panel by two rivets. The center hole is for the screw that holds the filler panel to the body. Two questions: (1) Do the steel plates attach to the underside of the body panel so that only the rivet heads are visible from the rear of the vehicle and, (2) are the visible rivet heads painted the body color or left natural? Thanks...Clark
    • 6950
    Re: Rear Body Filler Panel Attaching Reinforcement Plates -1970
    Clarke, the plates are attached to the underside, and not sure about the paint on the rivit heads but would say they were painted , I don't believe that you can see them any way once the exhaust panel is in place.
    • Clark E.
      • March 1, 1991
      • 163
      Thanks Ed. You're correct, the rivets are behind the filler panel once installed and are not visible...Clark
      • Wayne W.
        • April 30, 1982
        • 3605
        Now the question, were they painted? They were on the body at painting, but if the body was done the same way the midyears were done, the panel was bolted on during paint. That would mean the rivots were not painted.
        • Kurt G.
          • April 30, 2005
          • 343
          On my untouched '72 the rivets are painted body color, although 41 years has worn most of it off.
          Kurt Geis
          Chairman, Midway USA Chapter
          Targa Blue 1972, Top Flight and Duntov Award, 2014
          Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
          Arctic White 2013 60th Anniv Special Edition Conv.
