Master cylinder leak - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    I cant seem to stop the connection at the front of the master cylinder from leaking. I put in all new parts, the big nut and copper washer, the brass block and two new copper washers and even the bolt. Now it leaks more than it did before. What is the torque for the big nut? What is the torque for the bolt? I've just about had it with this. Any ideas would help.
    • 6957
    Re: Master cylinder leak
    Dave, sometimes it really takes some torque to get new coppers washers to seat properly, I seen posts like this more than a few times here. I work in a Automotive shop and see this quite often on disc calipers. don't be afraid to give it an extra pull with the wrench. Also make sure the copper washers are the correct diameter.
    • Bob H.
      • July 31, 2000
      • 827
      David,
      Before tightening it again, I would lightly lube the bolt. It may help cut resistance when you tighten it. I did have to exert some pressure on mine as well
      • David H.
        • November 11, 2009
        • 777
        This is a picture of the setup i used to tighten the big nut against the copper washer. I was afraid i was going to break something. A standard 1/2" ratchet with an 11/16 boxend wrench for more leverage. I really reefed on it. I give up!!!
          • 6957
          Dave, have you compared the parts you are replacing to the ones you took out ? Is the bango bolt have the correct number of threads, lenght ? copper washer thickness. brass block same thickness? Food for thought. can you re-install the old parts and check?
          • David H.
            • November 11, 2009
            • 777
            Here's a picture of the old and new setups. All the same except the wider copper washer on the large nut.
            I have re-assembled it tonight using permatex thread seal with teflon as i saw in an earlier post about this problem
            Hope it works.
            • David H.
              • November 11, 2009
              • 777
              The permatex thread sealer seems to have worked. When bleeding the brakes there was one tiny bubble that appeared for a moment at the large nut but then went away and did not return. I have a very good solid pedal. NAPA auto has the thread sealer with Teflon.
