C2 Holley 3367 Fuel Bowl/Metering Block Replacement Source - NCRS Discussion Boards
  • Frank C.
    • August 31, 2003
    • 171
    Good morninig,
    I would like to replace the fuel bowls and Metering Block on my Holley 3367. When I contacted Holley, they told me they did not stock the part, refered me to a vendor that only sells complete carbs. Is my only option to watch ebay and other places for used parts?
    Frank
    Frank Clark
    U.S. Army Retired, current serving DoD Civilian
    C1 1962 300hp, 4spd. Black/Fawn
    C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
    C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
    C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
  • Michael H.
    • December 1, 1987
    • 730
    Re: C2 Holley 3367 Fuel Bowl/Metering Block Replacement Source
    Try Chicago Corvette Supply.
    • Frank C.
      • August 31, 2003
      • 171
      Mike,
      I have seen their adds, but feedback on company service looks pretty grim. I will call to see availability and ship time. I am hoping for another source.
      Frank
      Frank Clark
      • Timothy B.
        • April 30, 1983
        • 5194
        Frank,
        Can you explain why you want to replace the bowls and metering block, when the bowls leak epoxy can be used and it works well.
        If the metering block is the original there should be a holley # stamped in the top and the replacement block will not have these numbers. The idle feed restriction and emulsion holes are located inside this part and are calibrated for your engine combo so be careful.
        • Joe M.
          • February 1, 2005
          • 590
          You might try to get one of the books on Holley carbs and check out the numbers for the parts as the same parts were used on different model carbs for other car models like chrysler or ford. Holley carbs for those models would be cheap.
          • William F.
            • June 9, 2009
            • 1364
            One of the carb restorers who have been mentioned in previous threads may have parts.Eric Jackson or Jerry McNeish, etc.
            • Michael H.
              • December 1, 1987
              • 730
              Originally posted by Frank Clark (40549)
              Mike,
              Frank
              I've seen comments but I have order from them with no problems. I order a correct metering block for my 67 L79 carb and it work fine.
              Mike
              • Joe R.
                • May 31, 2006
                • 1822
                Bill,
                Jerry MacNeish does a lot of things, but I don't think carbs are one of them. Jerry Luck or Bob Kunz might be able to help.
                Joe
                • Dick W.
                  • 10483
                  Run Forrest, Run
                  Dick Whittington
                  • William F.
                    • June 9, 2009
                    • 1364
                    Joe,
                    Don't mean it personal, but did you look at MacNeish's web site before saying he doesn't do carbs? He certainly does; many members have shown examples of his work on this forum. Again, not personal, but for these technical discussions to be helpful, contributors should make sure of facts before giving advice. Some say "I really don't know anything about xyz but blah, blah, blah," which is not helpful at best and often misleading.
                    • Frank C.
                      • August 31, 2003
                      • 171
                      I appreciate all who have responded. I am not going to buy through Chicago Corvette. I cannot support bad business practices.
                      To answer those that have asked, I purchased a dated carb from a guy who quit on a restoration. he had the carb rebuilt by a shop in Ohio. Both fuel bowls were epoxied over with grey epoxy. I know that this is common practice, but as I complete my engine rebuild I have spent considerable time and money to achieve proper finishes, I am having a hard time accepting the current grey epoxy solution. In addition, the secondary fuel bowl also had a stripped fuel valve seat lock screw.
                      One other issue/question I have is the metering block. Is the one I have a restamp? I have posted a picture for comment.
                      Since replacement parts are hard to come by, I have removed the grey epoxy from the fuel bowl, and am going to try a clear marine epoxy. I am going to rebuild the carb and run as is.
                      Again, thanks for the help and comments.
                      Frank
                      Frank Clark
                      • Joe R.
                        • May 31, 2006
                        • 1822
                        Bill,
                        Somehow I missed that Jerry MacNeish did carbs. Sorry about that. I did not check his web site first. My bad.
                        Joe
                        • Timothy B.
                          • April 30, 1983
                          • 5194
                          Frank, IMO, the 4743 metering block is correct for your carburetor and the double stamp looks OK to me. Many times people epoxy these bowls just to be safe so if you use the bowls it's better to be safe so be careful here.
                          I have purchased a secondary throttle shaft from Chicage Corvette without any problems and I know he sells on ebay. Unless someone can report bad business practices from them it's not fair to criticize FWIW.
