Need help on a factory mis-stamped 1965 Silver interior Trim tag - NCRS Discussion Boards
  • Bill C.
    • May 31, 1989
    • 424
    Hi,
    I am currently restoring a 1965 Corvette Coupe, delivered new to Jim Rathmann of Melbourne, Florida, title stated on it "U-Rent-It Program" when it was purchased used in 1971 at Spence Chevrolet in Daytona Beach, Florida . I verified the delivery with our Historic Document Services also, It's a silver coupe with a silver interior, optioned with 350 hp 327 engine, 4-speed, CR transmission, non-posi 3:55 rear, P/S, P/B, A/C, telescoping column, P/W, full tint. It must have been stunning new and really looked like a rocket!
    Here is my dilemma, the entire interior was spray dyed black sometime in the 70s, even the headliner was sprayed, it appears that they did recover the seats in black, although dyed the silver backs, the vinyl has the right pattern but is not typical "grain". So its obvious everything was originally silver, including the original door panels which are still with car and dated appropriately.
    The trim tag reads 426AA for silver vinyl and QQ for silver body, it has a built date of H11, March 11, 1965. ST Louis Built. The problem is in the ECL code, which reads AA, which is base for coupe and excludes, N03, M35, and A31. Obviously there is no auto trans or big tank, but it definitely has power windows and was definitely built that way. No doubts about it. I was pretty concerned as one could imagine, but it is absolutely an original tag also. First I thought maybe it had leather as that ECL code would have been 427, one digit off as AA in that version does not exclude P/W.
    After talking with some very helpful members I was informed that in the current version of Volume #1 of the Authentication Library book, it is noted that there have been several documented cases of this exact scenario involving Convertibles. Its right on page #53. (I must have an early version of Volume #1 as it's not in mine! So I was really excited to learn this, and same member was good enough to fax me a copy of that page.)
    "Several 1965 Convertibles with 426BA Silver Vinyl interior trim designation have been confirmed as being built with excluded options listed in Schedule #2", it further states" Some 1965 #426BA Silver Vinyl Corvettes with authentic trim tags may be properly considered to have no restrictions as to the presence or absence of interior options." "This note confirms that, on occasion the 426BA Silver Vinyl exception code may have been treated as if it was 427BA Silver Leather with respect to restrictions" ( I cannot understand what difference it would have made to a P/W or Auto Trans install being OK with Leather, but not vinyl seat cover?)
    So, here is my thoughts, that this being the case for convertibles, would this not apply to Coupes as well as an exception? It appears that way but it would be nice to get some more feedback. I cannot imagine what would have been different between a coupe and convertible if they were making the same mistake.
    Are there any cases documented of this being the case in Coupes also? If so, will that be added to the next release of Volume #1?
    Thanks!
  • Bryan H.
    • August 31, 2004
    • 120
    Re: Need help on a factory mis-stamped 1965 Silver interior Trim tag
    i have a 1965 Silver coupe with a silver interior. It is coded vinyl but actually leather. what are you seeking Bryan Hepper
    • Matt L.
      • February 23, 2010
      • 337
      hi Bill,
      i had the same concern on my 64 red with red vinyl fuel injected convertable. according to noland adams book my car was not supposed to have power windows but it did. it was a real car with real options. i have no doubt that this is the way the car came from the factory. your car sounds like it is ok as well. i would not be concerned. sounds like a neat car.
      take care,
      matt
      • Bill C.
        • May 31, 1989
        • 424
        Bryan, Was wondering if the documented tag mistamped ecl codes on the convertibles was also done on coupes, obviously in my case it was, but would like to hear about others. What is the ecl code on your car and what options does it have?
        Bill
        • Bill C.
          • May 31, 1989
          • 424
          Originally posted by Matt Lewis (51475)
          hi Bill,
          take care,
          matt
          Matt,
          Thanks for responding, sounds like you have a similar situation. Hoping to hear about other cars as mine, but as you indicate, this is probably not the only situation.
          Thanks!
          Bill
          • James G.
            • May 31, 1976
            • 1556
            Mike Doty and others have a 65 SILVER REGISTRY. SEE https://www.forums.ncrs.org/showthre...ilver-registry
            I have two examples, but both are A.O, Smith bodies. Each have only one letter or 426A and 426B.
            I think you ought to ''drive it like you stole it'', and not worry about letters on the ORIGINAL TAGS. Just because it is written down does not mean there are NO exceptions.
            • Bill C.
              • May 31, 1989
              • 424
              Hi Jim,
              Thanks for the info! Much appreciated.
              Bill
              • Bryan H.
                • August 31, 2004
                • 120
                Bill
                i am sorry i just saw this i will read my vin tag on my silver coupe this wee end and document its options
                Bryan Hepper
