Before and After. Getting Close - NCRS Discussion Boards
  • Gary A.
    • May 31, 2001
    • 165
    64 corvette parts for ebay 001.jpg1964 corvette 001.jpg Body and paint by the Bow Tie Shop in Billerica Mass. Thanks to Joe Scafidi and crew. The car is coming together. gary
  • Paul J.
    • September 9, 2008
    • 2091
    Re: Before and After. Getting Close
    Looks good, but while you're there you might as well remove the rest of the body. If for no other reason than to properly check and paint that rusty frame. It's called the "might as wells".
    Paul
    • Gary A.
      • May 31, 2001
      • 165
      you mean like this.
      • Donald O.
        • May 31, 1990
        • 1593
        Yes. Your drive shaft shouldn't be black though, IIRC.
        DonO
        • Paul J.
          • September 9, 2008
          • 2091
          Originally posted by Gary Azarian (36258)
          [ATTACH=CONFIG]44226[/ATTACH]
          you mean like this.
          Ha! Perfect.
          • Mike E.
            • June 24, 2012
            • 920
            Looks great! Nice shine not over done, what did you use for paint? Also just curious who did you get your front clip from? My car had a light front hit and wasn't repaired very well so front clip should be replace.
            Thanks!
            Mike
            • Gary A.
              • May 31, 2001
              • 165
              The nose came from semersheims.
