C3 Front Clip Instalation - NCRS Discussion Boards
+ More Options
Posts
  • Sheldon S.
    • March 1, 1999
    • 478
    I am ready to install the front clip on my c3, I have the body on the frame with body mounts and bolted down. Also have front rad support in place and inner fenders mounted to it. I will install hood on front clip. OK now after fitting clip to firewall area and inner fenders, marking fit position. What do I glue first, or do I try and put adhesive on all bonding areas for firewall and inner fenders and try and get the whole thing back in position before adhesive hardens? can you glue inner fenders first and then do the firewall bond later? How much adhesive do you put on each bond joint? The front clip I have is from corvette image with there bond adhesive.
    Sheldon
  • Pat B.
    • April 14, 2012
    • 7
    Re: C3 Front Clip Instalation
    The best fiberglass repair/rebuild resource I think is the CD by Glas Ra. Corvette Central has the best price. Step by step how to attach front clip is in volume 3 I think.
