I have a couple of questions on replacement parts for the my drivers door window glass and rear channel runs. Separation of the door glass from the sash is what started all this. Managed to get everything apart and then began looking at the usual vendors for parts. My old sash liner looks like a channel with a bottom about 1/4" thick and sides that would hold the glass. The catalogs show something called sill tape. When I think tape I envision something like duck tape. What is the correct replacement part called and who has it? My concern is by using 'tape' the glass would sit deeper in the sash causing fitment problems.
My other question is the rear channel liner. My rear channel liner was a separate piece from the liner that goes around the door from the vent window to the rear. It was glued in the channel without any clips or a screw at the bottom of the channel. The rear channel has only one hole at mid length. The catalogs show a one piece liner that goes from the vent window to the bottom of the rear channel. What am I missing? This is a mid April build 66 Coupe. Was there design change?
Others have done this I'm sure. Any recommendations?
As always, thanks in advance.
