1957 FI unit - NCRS Discussion Boards
1957 FI unit
  • Michael J.
    • January 27, 2009
    • 7122
    1957 FI unit
    I am looking at a '57 FI and the unit has a serial number of 11 0 9 and a part number of 7014800. Is this a '57 unit? Thanks.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17672
    Re: 1957 FI unit
    Mike,
    4800 is a late '57 FI unit. What is the car's VIN ? The unit may or may not be appropriate for the car. Does the FI fuel filter input/output line bosses on the filter have round or square bosses?
    Have you bought a 1956-7 Judging Manual?
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John D.
      • December 1, 1979
      • 5507
      Re: 1957 FI unit
      Michael, Check out the FI distributor as well. See if the suffix on the tag reads 905 or 906. A typical 4800 LHP FI car will have a '906 distributor. Single points and hex vacuum advance. Now to wait until you answer Gary's good question.
      I really should order the latest 56-57 manual Gary. John
      • Michael J.
        • January 27, 2009
        • 7122
        Re: 1957 FI unit
        Yes, thanks for all that. It has round bosses it appears, and it is a late build (June estimate). I will buy the manual, I obviously have lots to learn
        • Gary C.
          Administrator
          • October 1, 1982
          • 17672
          Re: 1957 FI unit
          Mike,
          FI fuel filter was changed from round to square bosses (to hold wrench) approximately VIN 3400
          VIN 3200~6339 FK 250HP engines could have 4800 units with 906 distributor
          VIN 4800~5584 EL 283HP engines could have 4800 units with 905 distributor
          Is it a 4800R unit?
          No 4 speed transmission was available until approximately VIN 3467
          Helpful for you to post the VIN. You don't have to post the full VIN, it could be posted like 43XX. That would be beneficial for everyone that's trying to help you.
          Gary
          NCRS Texas Chapter
          • Michael J.
            • January 27, 2009
            • 7122
            Re: 1957 FI unit
            Yes, it is a 906 and a three speed. Don't want to be mysterious, but the owner has not confided the VIN in me just yet. I was working off some hi-res photos and just trying to determine if the FI unit was indeed a 1957, thanks all.
