1965 Antenna Thread - NCRS Discussion Boards
1965 Antenna Thread
  • Wes W.
    • September 6, 2010
    • 12
    1965 Antenna Thread
    NCRS help!
    My 65' antenna nut won't quite grab the antenna thread. My thought is to try to out a die thread and straighten out the threads on antenna bolt. Does anyone know the correct size (it appears to be 7/8" dia)? Not sure about the number of threads but it appears fine vs. coarse.
    Any advice on helping to make the connection more sound is appreciated.
    Wes Wells
    Member 52165
  • William F.
    • June 9, 2009
    • 1364
    Re: 1965 Antenna Thread
    Are you sure metal ground plate under fender that antenna goes through is on correctly so as not to prevent antenna from going all the way up through fender so nut will "catch" a thread?
    • Wes W.
      • September 6, 2010
      • 12
      Thanks for the advice. I'll check.
