cluster fix question - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    Require info if anyone has had to fix a cluster that has been butchered . I was thinking of making a fiberglass piece covered with JB weld.
    Also required to be painted. I 'm not sure if this material can be welded ? If so maybe aluminum patch ? Also require any measurements of origanal piece.
    Thanks Winter projet.
  • Wayne P.
    • January 23, 2008
    • 444
    Re: cluster fix question
    Project coming along Used t3 aluminum and weld bond. Yes it's a driver.
    • Paul J.
      • September 9, 2008
      • 2091
      Wayne, to answer your first question, it can be brazed. Since you have already repaired this, perhaps this can be for future reference. I believe that the cluster is pot metal. You can use Muggy Weld products to weld a patch in. I believe that too much is broken off to build this area up using these products.
      It's looking pretty good.
      Paul
      • Wayne P.
        • January 23, 2008
        • 444
        Thanks Paul a few more touches to go.
        • Dale M.
          • December 27, 2007
          • 386
          Thanks York for your posting. This seems to be a fairly common issue on mid-years, I have a '64 with the same kind of break. Don,t have the broken off piece. I purchased another cluster and had it chromed. I may attempt to repair my original. Thanks for the information. Dale
