Is it the starter or the battery? - NCRS Discussion Boards
  • Michael A.
    • March 1, 1996
    • 507
    Need some help on the diagnostic procedure I should use to determine if I have a battery or a starter problem. Here's the situation:
    • 66 small block, 327/300
    • 9 year old rebuilt starter, approx 30k miles since it was rebuilt.
    • approx 7 year old battery with disconnect switch mounted on positive terminal
    • when I turn the ignition (engine cold or hot), it turns very slowly and may or may not fire up
    • I have cleaned the battery terminals and fully charged the battery. Battery measures 12.5v after charge.
    I'd appreciate suggestions on what I should check to determine if it's the battery, starter, both or something altogether different I should be checking.
    Mike Andresen
    Bloomington, IL
  • William C.
    • May 31, 1975
    • 6037
    Re: Is it the starter or the battery?
    Many things to check, but I'd start with how does the battery voltage hold up UNDER LOAD? What does the voltage drop to when cranking might be a good number to know regarding the health of a 7 year old battery.
    Bill Clupper #618
    • Michael W.
      • April 1, 1997
      • 4290
      Try jumping the battery from another car. If the engine spins at a higher speed, it's not the starter.
      • Michael G.
        • January 1, 1997
        • 1251
        Let's see....car driven sparingly, 7 year old battery......surprised battery has lasted this long. Do not see the starter as the issue. If your in doubt battery is the culprit, start car with another battery. Believe you'll be shopping for a new battery.
        • Michael A.
          • March 1, 1996
          • 507
          Thanks for the tips all. I followed the suggestions and here's the results:
          - Jumped started it and the starter spun faster
          - Checked voltage drop when the ignition was turned - voltage dropped to 4.5v
          Sounds like it's the battery.... a much easier item to replace. Any other items I should be checking before I head out to purchase the new battery? Suggestions on brands?
          Mike Andresen
          Bloomington, IL
          • Michael A.
            • March 1, 1996
            • 507
            Michael
            Yup it's an old battery but I just replaced the original battery in my 2003 daily driver with 165k on the odometer. A battery would be far easier to replace than the starter.
            Mike Andresen
            Bloomington, IL
            • Bruce B.
              • May 31, 1996
              • 2930
              I like the AC Delco batteries. Probably now made in Mexico but I have great performance using them for many years and still have a few 4 to 7 years old that work as designed.
                • 15601
                We have visited this subject recently;
                https://www.forums.ncrs.org/showthre...-Battery-Drain
                https://www.forums.ncrs.org/showthre...e-on-Batteries
                • Michael A.
                  • March 1, 1996
                  • 507
                  Hi Terry
                  Thanks for the links. I had found the second thread when I did my search before posting but not the first. Lots of good info in both but I was looking for the right troubleshooting steps. As always, I got some great assistance from the TDB. I now have a new battery installed and it's cranking great!
                  All of the folks on the TDB are a god-send to people like me. The wealth of experience gives me the ability to keep my car running and keep me smiling. Thanks to all!
                  Cheers
                  Mike Andresen
                  Bloomington, IL
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Glad to hear that it was an easy fix.
                      • 15601
                      Mike,
                      I was replying to your "Any suggestions for brands?" comment. I thought those two threads about sums it up for brands. I guess I could have/should have made that clearer.
                      • Paul J.
                        • September 9, 2008
                        • 2091
                        Don't over think these things Mike. Just remember that it takes amps to turn the flywheel. A battery that shows 12 volts may not have any amps, and this is usually the case.
                        Sometimes a duck is just a duck.
                        Paul
                        • Michael A.
                          • March 1, 1996
                          • 507
                          Thanks Paul. This duck was definitely quacking. I just wanted to make sure I was hearing it right
                          For me the thinking part is a big part of the fun. I don't do this stuff every day so the TDB is my go to source to help me think things through. I fully understand your comment about amps I just didn't know how to measure the amps. The suggestion of jumping the car to see if the starter turning faster (which it did) confirmed that the starter was not the problem. So by simple process of elimination, it was clear that the battery was the source of my trouble. The new battery did the trick. I hope it lasts as long as the last one did!
                          Cheers,
                          Mike Andresen
                          Bloomington, IL
                          • Michael A.
                            • March 1, 1996
                            • 507
                            You're a star Terry. Thanks for the help. I definitely love the "search" function and the wealth of info on this board. It is amazing!
                            Cheers
                            Mike Andresen
                            Bloomington, IL
                              • 15601
                              Cheers,
                              Mike,
                              There is a third player -- besides the starter and battery -- the wires and connections. Without good clean, tight connections and wire of adequate size one can chase ones tail around on a hard start issue.
