1960 Part Look Up - NCRS Discussion Boards
1960 Part Look Up
+ More Options
Posts
  • Joe M.
    • April 30, 1990
    • 1342
    1960 Part Look Up
    To install the fan clutch on the fan blade assembly, the 1960 AIM calls out two types of washers, 120214 L.W. which is a 5/16" lock washer and 3772747 S.W. I could not find the S.W. part in my Chevy P & A Catalog, dated Feb. 1, 1961. Is it some type of spring washer? If so, what is the modern equivalent?
  • John F.
    • March 23, 2008
    • 2415
    Re: 1960 Part Look Up
    I thought it stood for "split washer" which is a lock washer in my mind.
    • Joe M.
      • April 30, 1990
      • 1342
      I suspect that there must be some difference or there would not be two different part numbers. I am surprised it was not listed in my 1961 updated Chevy P&A.
      • John F.
        • March 23, 2008
        • 2415
        Joe, also "star washer".
        • Joe M.
          • April 30, 1990
          • 1342
          John, GM called them external tooth lock washers in the Parts & Accessories book.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11345
            Joe, 3772747 never shows up in a search on http://www.gmpartswiki.com in any book listed.
            I think it's a Spring Washer as you do. In Group 8.928 in the P&A 30 parts Book, it shows several sizes, but notice not 5/16". I suspect 3772747 was never a Service part.
            http://www.gmpartswiki.com/getpage?pageid=67140 (see lower right corner of page)
            Can you post a picture/scan of your 1960 AIM showing where the 3772747 SW is placed?
            Rich
            • Joe M.
              • April 30, 1990
              • 1342
              I included it in current post titled "Original Copy of 1960 A.I.M."
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11345
                Strange.......Maybe "SPECIAL" washer. ????
                Assy shows Bolt, then LW then SW. Maybe it has a special bevel to allow it to be flat to the flange which also appears beveled.
                • Joe M.
                  • April 30, 1990
                  • 1342
                  I figured it out in a roundabout way by looking at page 964 of 1961 P&A. It shows a 5/16" washer in Group 8.929. It was probably referring to a 5/16" cadmium-plated plain washer (small), P/N 120393. With a slotted mounting plate, it would make sense to use a plain washer between the slot and the lock washer. The 1960 AIM reference is a typo.
