1958- ??? Window Cranks - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    Good day all!
    Are the later NOS window cranks exactly the same as the originals? All the repros are el-cheap-o's which are made in China. If the NOS cranks are very close to the originals, can you guys lead me in the right direction to where I may find a pair for a fair price?
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 1958- ??? Window Cranks
    originals have a shamrock embossed on their bachsides. mike
    • Joe M.
      • April 30, 1990
      • 1342
      I have had my 1960 Flight judged 3 times with zero deduct from repro window cranks. They are cheap and cheaply made. The last repro window crank I purchased would not slide onto the regulator post far enough to pop the spring clip in place. Used a file to file down the space between each tooth on the window crank. Handle then fit deep enough on the post and spring clip snapped into place.
