Does the shutoff have an O ring on the end of the turn screw inside the casing? Also how do you get the screw shaft out of the casing with the packing around it, can you still get the packing or whatever this piece is, get it in and out without a problem. If I close mine I can still blow air or water through it, off the car. Thank's, Brad.
