Correct Repoduction Expansion Tank Cap 1966 Roadster - NCRS Discussion Boards
  • Dan L.
    • May 9, 2012
    • 97
    I am trying to determine the correct (repoduction of original) expasion tank cap for my 1966 327/350 non-ac roadster. I just purchased the 1966 NCRS Technical Information & Judging Guide and I can't find any reference to the expansion tank or cap. Ecklers list a repoduction cap for 1964L - 1972 with a AC Logo RC-26/15# and Zip lists a repoduction cap for 1964-67 with a AC Logo 307/13#. Any information is appreciated.
    Dan #54915
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Correct Repoduction Expansion Tank Cap 1966 Roadster
    Dan #54915
    Dan,
    Newest judging manual, check page 163....AC logo RC26 15lb cap.
    • Dan L.
      • May 9, 2012
      • 97
      Thanks Michael
      • James S.
        • July 31, 1990
        • 126
        Dan, you may find it difficult, if not impossible, to find a reproduction RC 26 radiator cap that will pass NCRS judging.
        Original RC26 caps are configured with distinctive "large" ears. directional turn arrows with closed triangled shaped tips and indentations on the edges - all attributes pictured below.
        • Larry M.
          • January 1, 1992
          • 2701
          [ATTACH=CONFIG]43845[/ATTACH][ATTACH=CONFIG]43846[/ATTACH]
          I agree. Probably the closest reproduction is the RC 26 cap from Long Island Corvette Supply. Even so, it is not exact. And if you buy one, I would suggest checking it with a radiator cap presssure tester. The one I purchased did not relieve pressure until 20-25 psig. This was just too high for me and my 45 year old Harrison radiator. So it is sitting on the shelf at this time.
          Pete Lindhal may be able to help with a restored original. But they are not inexpensive.
          Larry
          • David L.
            • July 31, 1980
            • 3310
            There were several variations of the RC-26 cap. The original RC-26 cap pictured below was attached to an early 1969 Corvette supply tank stamped "3016340" and "68H" (Aug. 1968) that I bought at a swap meet last Fall. It may or may not be correct for correct for other model years.
            Dave
            • James S.
              • July 31, 1990
              • 126
              IMO this configuration is correct for earlier models.
              There is a later flat rivet version that is not considered original to 67 and earlier models.
              Dave
              • Dan L.
                • May 9, 2012
                • 97
                Thanks to all for the information and pics, I'm relatively new to the restoration process - bought my roadster last July. Where can I find an (expensive) refinished original. The one on the car appears to match the pics you sent - can these things be refinished to NCRS standards?
                • Russ S.
                  • April 30, 1982
                  • 2163
                  Try Joe Perri from Chicago. I believe he advertises in the Driveline.
                  • Dan L.
                    • May 9, 2012
                    • 97
                    Thanks Russ - I'll check Joe out.
                    • James S.
                      • July 31, 1990
                      • 126
                      Also, check with John Pirkle both for restoration of your old cap and an already restored RC26. John also advertises in the Driveline. Contact information is: John Pirkle,3706 Merion Drive, Augusta, GA 30907(706) 860-9047 pirklesr@juno.com
                      • Dan L.
                        • May 9, 2012
                        • 97
                        Thanks James
                        • Gary B.
                          • February 1, 1997
                          • 7053
                          James,
                          According to recent postings, I believe that John Pirkle no longer restores expansion tank caps.
                          Gary
                          • John P.
                            • August 31, 1991
                            • 94
                            Gary is correct,I am no longer able to restore radiator caps(we havent for 7 or 8 years)
