72 Headlight mounting cups - NCRS Discussion Boards
  • Rey S.
    • April 1, 1995
    • 277
    All my catalogs and assembly manual show an inner (r&l) mounting cups and an outer (r&l) mounting cups. OK fine but which one is which ???
    Thanks for any info.
    Rey Stenhouse (26007)
    • 6960
    Re: 72 Headlight mounting cups
    Ray, I think the high beam and low beam headlamps have different mounting tabs , so the high beam won't fit into the low beam. and vice virsa.
      • 43289
      Roy-----
      All 4 are different.
      left inner= "D"
      left outer= "A"
      right inner= "B"
      right outer= "C"
      These stampings are on a small tab on the ring ("cup"). Earlier model Corvettes used different identifying stampings.
      • Rey S.
        • April 1, 1995
        • 277
        Thank you folks for the Information how ever ------------------ I played with these cups all day Saturday and found them to be totally interchangeanble ( at least to mounting into the headlight doors ) without installing the lenses. Could these "cups" that I have be aftermarket reproductions with universal tabs as the car was hit in the front end many many years ago before I aquired it ???
        Thanks for the info.
          • 43289
          Rey-----
          By "lenses" do you mean SEALED BEAMS? If so, that's where you're going to find the difference lies. There are "reliefs" on the RINGS into which fit locating "nubs" on the sealed beams.
          I do not know if there were ever aftermarket rings available which were "one-size-fits-all". I kind of doubt it but I suppose it's possible. Do your rings have the alpha stampings I described above? You'll have to look closely as the stampings are quite small and sometimes lightly stamped. If your rings are the black-painted variety sometimes the paint kind of "fills in" the stamping.
          • Rey S.
            • April 1, 1995
            • 277
            Hi Joe
            Two of the cups have stamping. One has a letter "D", One has a #1(I ? Can't tell, very faint) The others have nothing.
            Rey
            P.S. I will check how my sealed beams fit.
              • 43289
              Hi Joe
              Rey
              Rey-----
              Could the "1" be an "L-1" or "R-1"? . The alpha-numeric stamping protocol was generally used prior to about 1970.
                • 15640
                My best recollection, and it has been many years since I changed one of the bulbs, my early 1970 has rather large A B C D. Say maybe 1/2-inch high.
                • Clark E.
                  • March 1, 1991
                  • 163
                  My late March, 1970 conv. headlight cups have the same A B C D markings...Clark
