65 Brake lines - NCRS Discussion Boards
65 Brake lines
  • Murray S.
    • May 31, 1990
    • 75
    65 Brake lines
    When did the switch occur from 3/16 to 1/4 inch brake lines? I want to change my brake lines back to steel lines in preparation for National Judging. My serial number is 3124.
  • John M.
    • January 1, 1998
    • 813
    Re: 65 Brake lines
    Murray,
    I believe all 65 brake lines were 3/16" and all master cylinder fittings were 3/16" with no adaptors.
    John
    • Gene M.
      • April 1, 1985
      • 4232
      Re: 65 Brake lines
      Originally posted by John McRae (30025)
      Murray,
      John
      No, not true, The drum brake cars (around 300 or so) do have a 1/4" line from the master cylinder to the brass block at the left front corner of the frame.
      • Michael G.
        • January 1, 1997
        • 1251
        Re: 65 Brake lines
        Has your car been judge Regionally? If so what were the results regarding the brake lines? Some one will correct me if I'm wrong but believe to be judged Nationally one has to go through Regional Judging.
          Re: 65 Brake lines
          Michael -
          Although that's an excellent idea, it's not a requirement - the only prerequisite for National judging is a Third Flight or higher award, under the same owner, within the three years preceding the National Convention. Probably not a great idea to go to the National without going through Regional judging first, to avoid disappointment.
          • John M.
            • January 1, 1998
            • 813
            Re: 65 Brake lines
            Thanks Gene,
            I did not know that. Do those have a bushing in the MC from 3/16 to 1/4?
            John
              Re: 65 Brake lines
              Thanks Gene,
              John
              John -
              J-61 (drum brakes) used a different master cylinder, which had a residual pressure valve in it - the part number for the J-61 master cylinder and the 1/4" front line are shown in the J-61 Section in the Assembly Manual.
              • Murray S.
                • May 31, 1990
                • 75
                Re: 65 Brake lines
                Michael: yes my car has been judged regionally. Top Flight at Altoona September 2012
