Re: Rag Joints
I was a product engineering supervisor at Saginaw Steering Gear Division, GMC, from 1971 through 1986. I was responsible for flexible steering shaft coupling assemblies. So a lot of basic design work was done on connection designs just before I became supervisor. The following are the basics.
The first thing to remember is that we are dealing with a critical safety connection with respect to steering your car. That criteria was always foremost when making any type changes to the flange to steering gear, or flange to steering column shaft connections.
This is the philosophy concerning the flex coupling flange connections. Tightening the pinch bolt to a specified torque was designed to "wrap" the flange barrel around the gear input shaft. That is why, in most cases when working on a vehicle, the pinch bolt is removed and yet the flange still needs to be "persuaded" to come off the shaft. You usually have to jam a chisel point or a very large screwdriver into the saw slot in the flange barrel and cause the barrel to open slightly before the flange can be slipped from the shaft.
Early flanges (1963) had full serrations and it was noted that serrations all around the interior of the flange barrel actually hindered the "wrap". So through the years, based on tests, the number and location of the serrations were modified. On the 1963 to 1966 drawing above you can see where serrations were eliminated on 1/4 of the interior of the barrel. For the most part, serrations were eliminated to improve the "wrap". Please note that the Saginaw flange drawings in many cases were updated to reflect the latest design for service parts. That is why my 1963 drawing doesn't necessarily show the full serrations.
Also, starting in late 1969, a flat was added to the gear input shaft and a corresponding flat was added to the coupling flange. The flats aided in installing the coupling assembly in the correct rotational location. This eliminated several more serrations where the flat was located.
For the most part, if the pinch bolt was torqued to specification, the connection was secure for the life of the vehicle. Problems could occur if the pinch bolt was not tightened. So a nylon patch was added to the pinch bolt threads in 1969 such that you cannot install the pinch bolt with just your fingers. You must use a tool to draw it down. Therefore, it is assumed that if you used a tool, you would also apply some amount of seating torque.
In my humble opinion, if the pinch bolt is torqued to specification (i.e. 25 to 35 ft-lbs) the connection would be secure regardless as to the number of serrations.
Jim
Jim
