439 big block - is this stamp pad original? - NCRS Discussion Boards
  • J W.
    • January 1, 2004
    • 62
    I am considering the purchase of this 439 block but would like some opinions as to whether or not the engine ID stamp and broach marks appear to be original and how the block would fare on a judging field with the correct VIN stamp. Attached are the best photos I could get from the seller.
    Michael
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 439 big block - is this stamp pad original?
    The pad would most likely appear just what it could end up as, a restamp.
    • Michael G.
      • January 1, 1997
      • 1251
      Michael
      Assuming the casting #'s and date codes are correct for your car view the broach as good. However do see diagional swirl marks running left to right through the broach. Unsure to what degree marks would have during judging of the pad nonetheless will impact their decision 'does it appear as a typical'? Having the swirl marks won't help your case I believe. Are you contemplating having your partial VIN stamped into block?
      • Michael J.
        • January 27, 2009
        • 7121
        I agree those swirl marks on the right side of the pad are problematic, wonder if they ground off a partial VIN?
        • Jimmy G.
          • November 1, 1979
          • 976
          No Comments on the 1 versus the usual I Unusual to say the least if it is real
          • Dick W.
            • 10483
            Maybe the "Master" will see this thread and comment. It appears to be the block from a crate, across the counter, 1968 engine. I have another similar block in my photo collection, but four months from this one so not a good comparison.
            Dick Whittington
            • J W.
              • January 1, 2004
              • 62
              Thanks for the input. To my eye, it looks like original broach marks under the file marks and swirls. Has anyone ever seen a correct, original block with an engine ID stamp other than CE and no VIN stamp?
              i think 1 versus I has been documented in original engine ID date stamps.
              • Dick W.
                • 10483
                Seen, and purchased, several across the counter engine assemblies, most had machine code, and of course no VIN
                Dick Whittington
                • Patrick B.
                  • August 31, 1985
                  • 1995
                  It looks like a block from an over the counter crate L-88. The use of all three types of 1's in use in 68 at Tonawanda speaks in favor of its originality. The grain looks original with some unfortunate scuffing.
