rear sway bar install - NCRS Discussion Boards
  • Ed L.
    • October 24, 2012
    • 70
    Installing new endlink bushings in my 71BB. I am having a lot of problem installing them. Any suggestions on install technique and/or tools to use. thanks, Ed
    • 6950
    Re: rear sway bar install
    Ed,I think if you use a couple of 1/2 drive sockets with the correct diameters they will install. use one socket that is a big enough dia. for the receiver end and use another the same size dia as the metal sleeve to tap in the bushing in the link and bar. If you have something else you can use that is more correct than a socket use it. a socket sometimes does not alway have the correct dia. any way I think you have the idea. Use some grease to help them slide in.
    you can always head to the hardware store and take a bushing with you and get a 6" piece of pipe to use a driver.
    • Ed L.
      • October 24, 2012
      • 70
      thanks..that gives me a good idea
