Manifold bolts - NCRS Discussion Boards
Manifold bolts
  • Morris R.
    • May 7, 2012
    • 213
    Manifold bolts
    Merry christmas to all.
    What i can use to stop the oil from coming up from the manifold bolts. Is there anything out there that would stop this and is this normal for a corvette or for that matter any car? Thank you
    • 6950
    Re: Manifold bolts
    Morris, the two center intake bolts on each side are through bolts.You will need to take them out and clean the oil off the threads of the bolts and also the threads of the head and use some liquid teflon sealer on the threads.Cleaning the threads can be done with brake cleaner in the spray can, be warned that any cleaner of this sort wil eat the finish of the paint on engine or car. so be to use the plastic straw attached to the can that will let you direct a controled spray.
    • Morris R.
      • May 7, 2012
      • 213
      Re: Manifold bolts
      Thank you edward, would it be ok to spray the brake fluid down into the holes of the manifold to clean the threads? Have a merry christmas and happy new year!
      • Mike G.
        • January 1, 1991
        • 418
        Re: Manifold bolts
        Morris: I just did this using Q-tips and mineral spirits to clean the threaded holes. For a sealant, I use Permatex Aviation Form-a-Gasket. Best stuff I've found for this sort of application. Mike
        • Morris R.
          • May 7, 2012
          • 213
          Re: Manifold bolts
          Thank you mike, merry christmas and a happy new year!
          • Larry M.
            • January 1, 1992
            • 2701
            Re: Manifold bolts
            Agree with Mike.......but I would use a doubled over pipe cleaner instead of the Q-tip. Either one will work fine, but the pipe cleaner doesn't shed like the Q-tip.
            Since I'm very old school, I would probably use Permatex #2, but the Aviation sealant is probably much better. I just need to get some and try it on my next project.
            Larry
            EDIT: I have also used brake cleaner to clean threads like Ed stated, but if I sprayed a lot into the thread holes, I would probably change my oil after running the engine for awhile. Most brake cleaners are chlorinated hydrocarbons and can be corrosive if mixed with any moisture. No use taking any chance.
            • Morris R.
              • May 7, 2012
              • 213
              Re: Manifold bolts
              Thanks larry also let me ask a question , out of ten manifold bolts only two of them are pushing oil up what do you make of this? I might add the rebuilt motor only has 1,000 miles on it. Thanks merry christmas and happy new year!
              • Larry M.
                • January 1, 1992
                • 2701
                Re: Manifold bolts
                Morris:
                Only the center bolts are "through bolts" where the oil can wick up. So therefore there can only be four (4) that can/will leak on your intake manifold. So you are 50/50 on this. You can just do the two leakers, or you can do all four. Your choice.
                I had this problem on my 1967 327/350 HP engine, but stopped the leaks by just tightening the center bolts a bit more. They were loose. HOWEVER, do not overtighten the manifold bolts or you can crack the aluminum. Just a warning.
                Larry
                • Morris R.
                  • May 7, 2012
                  • 213
                  Re: Manifold bolts
                  What is causing this? Will it stop after awhile from being used?
                    • 6950
                    Re: Manifold bolts
                    Morris crank case pressure will push the oil up the center bolts.I believe the oil from the push rods drips down the sides of the cylinder head and the pressure from the crank case blow -by pushes the oil up the threads of those center bolts. this has been a problem since the V-8 chevy small block was produced. Keep in mind that a well sealed engine will look for places for the blow-by to escape. the PCV and Breather sometimes are not enough.
                    • Morris R.
                      • May 7, 2012
                      • 213
                      Re: Manifold bolts
                      Thanks edward
                      • Dick W.
                        • 10483
                        Re: Manifold bolts
                        Brake cleaner, not fluid!
                        Dick Whittington
                        • Morris R.
                          • May 7, 2012
                          • 213
                          Re: Manifold bolts
                          I'm sorry mis printed thank you
                          • Jaime G.
                            • April 1, 1988
                            • 480
                            Re: Manifold bolts
                            Dick,
                            you are so dilligent.
                            Happy Holidays to you and your family.
                            Jaime
