365HP engine rebuild with LT-1 cam, should I advance the cam/ - NCRS Discussion Boards
  • Craig F.
    • March 1, 1986
    • 55
    I am rebuilding my 365hp motor and using the solid LT-1 cam vs the 30/30 cam and wondered if anyone has advice if this cam should be installed 3-4 degrees advanced for best power and performance or at zero. Everything else regarding the rebulid is all stock.
    Craig
    • 15706
    Re: 365HP engine rebuild with LT-1 cam, should I advance the cam/
    No. Advancing a cam trades some top end for bottom end power - otherwise known as low end torque. The LT-1 cam provides a noticeable low end torque improvement over the 30-30. If you need more, get a milder cam. The LT-1 cam should provide about 80 percent of peak torque at about 2000. The 30-30 doesn't make 80 percent until nearly 3000. Big difference!
    I hope you're replacing the spindly OE rods with Eagles SIRs or something equivalent.
    And of course, head massaging and the LT-1 cam will provide useable power to about 7200, which the OE springs can handle with careful installed height setup - .090" coil bind clearance using maximum valve lift at a 1.44:1 rocker ratio.
    • Craig F.
      • March 1, 1986
      • 55
      I am using your 327 build advice that you posted a while back so I am using the Eagle rods, it actually did not cost much more after you price preping the stock rods so I considered it cheep insurance as this motor should pull to around 6,200-6,500 and I am only going to do this once. The 461 heads off my motor have been street ported in the past and have good springs in them now, when I got it someone put the 302 2nd design off road cam with these so I am thinking the springs should live fine with the LT-1 cam.
        • 15706
        "Good springs" are Sealed Power VS677, which are equivalent to the 3911068 OE springs. Nothing more, nothing less. They cost about a buck a piece. If you still have the off road Z-28 cam springs, get rid of them. If you set up the VS677 as I recommend valve float starts at about 7250.
        If your heads are properly massaged, it will make useable power to 7200.
        Did you have them flow tested?
        What is the data?
        • Michael G.
          • January 1, 1997
          • 1251
          What is the data?
          Which aftermarket vacuum advance would you recommend for this application?
            • 15706
            The answer is in my San Diego presentation.
            • Michael G.
              • January 1, 1997
              • 1251
              Ok Duke......since most of were'n't at SD and don't have the publication handy. Care to let us know?
                • 15706
                It's easy to find with Google. Search Duke Williams San Diego Corvette.
                • Michael G.
                  • January 1, 1997
                  • 1251
                  Anyone know which aftermarket vac can seems to work best in this application with the LT-1 cam. Thanks.
